Modify a definition query of a feature service after publishing to ArcGIS Server
716
11-08-2019 12:46 PM
Col_Forbin
New Contributor III
I published a feature class to ArcGIS Server 10.7.1 from ArcMap that had a definition query.  The service seems to be respecting the definition query just fine.  But now I'd like to modify the definition query.  Is there any way to modify it after it has been published?  Or can I at least see the syntax so that I can overwrite the service?
RobertBorchert
Frequent Contributor III
Expand the Feature that you want to update and there is a button called Filter which is the same as the definition query you set up.
Col_Forbin
New Contributor III
Is this in the Server Manager?
