Log file table configuration and editing versioned geometric network
2835
11-27-2015 02:55 AM
DariuszBiarda
does the log file table configuration parameter in SERVER_CONFIG SDE table has big influence on editing versioned feature classes via ArcGIS Server feature service? Since few months I have an issue with my web map ArcGIS Server 10.1 feature service which after few hours/days, after manual restart, stops saving edited data. ArcGIS Server logs show that the applyEdits  method's elapsed time increases up to several seconds. Oracle team says that DB is fine.
I do compress the GDB every night and run statistics/analyse as well.
What else can I do in order to avoid these problems? I have changed ALLOWSESSIONLOGFILE to true. What about service configuration? I have max. 8 simultaneous editing users - it is so little!
I would be very gratefull for help,
Bart
