I added a subtype to an existing list of subtypes for a subject feature class and is not showing up in my Create Features Tree. The original Feature class subtypes do appear except for the one created at a later date.
636
05-31-2017 08:01 AM
AlejandroDe_la_Rosa
Please see attached image below. Subtype Code 15, "Flush Valve w Gate Valve", does not appear on the Feature Class Tree on the right of the image.
Asrujit_SenGupta
MVP Regular Contributor
Did you close and reopen ArcMap and then check?
Add the Feature Class to a new MXD and then check if the new one shows up...
AlejandroDe_la_Rosa
Closing and re-opening arcmap did not help. adding the modified feature class to the mxd did work. The original feature class needs to be erased.
AbdullahAnter
Occasional Contributor III
Could you check by open attribute table and edit any value in the subtype field , see the menu if the new value included.
if so
add new this template by open organize templates, then New template and add all template.as the following picture.
