How to see license info on SDE 10.3.1 Geodatabase
3073
05-09-2016 07:04 AM
KevinEscalera1
Hi everyone, I have a question, is there a way to see the status of a license in Enterprise PostGreSQL Geodatabase?. I want to know when the license is going to expire and also be sure that the license has been replaced when I replace it with a new one.
thanks in advance.
PanagiotisPapadopoulos
connect from pgAdmin on your SDE geodatabase.
find on SDE schema the table sde.sde_server_config and preview the data.
the row with the value "AUTH_KEY" on prop_name field hosts the sde license
here you can see everything you want.
George_Thompson
Esri Frequent Contributor
You can look in the sde_server_config table within the SDE schema.
Look at the AUTH_KEY field, there will be a date field in the string.
I.E.: arcsdeserver,101,ECP#,02-JULY-2016, .............
System tables of a geodatabase in PostgreSQL—Help | ArcGIS for Desktop
--- George T.
KevinEscalera1
Thank you and George, for your quick response, I was able to do it
