How to search for a FC in ArcCatalog that is located in a FS
1170
6
04-08-2019 06:27 AM
JoseSanchez
Hello everyone,
Using ArcCatalog, how can I search for a FC that is located in a FD, but I do not know the FD where it is located.
JoshuaBixby
Are you looking a GUI option or some Python code to run in the interactive Python window?
JoeBorgione
+1 for Joshua Bixby‌'s comment
Your title indicates Feature Service (FS) but the body of your post indicates Feature dataset (FD).
DanPatterson_Retired
Walk? Walk—Data Access module | ArcGIS Desktop
Find the featureclass, hence the featuredataset.  Of course limiting the start point would be the key
As for FS? FD? which
Asrujit_SenGupta
MVP Alum
If the Database Connection is indexed, you can directly search in the Desktop interface.
Using search in ArcGIS—Help | ArcGIS Desktop
JoseSanchez
Good morning,
Sorry I mean Feature Dataset. We have an SDE database with more than 1000 Feature classes and tables. most of the FC are inside Feature Datasets.. So when we get a call for an user asking for the location of a FC it will be very helpfull to have a tool to search for a FC.
leomonterol
Hi Jose
You can use the script below in ArcCatalog's python window (Change fcName and pathToSDEConnectionFile)
# Feature Class Name (E.g. TestDB.DBO.TestPolygonFeatureClass)
fcName = 'TestGDB.DBO.TestPolygonFeatureClass'
# Path to the sde connection file
pathToSDEConnectionFile = r'C:\tmp\sdeConnections\localhost.sde'
arcpy.env.workspace = pathToSDEConnectionFile
datasets = arcpy.ListDatasets(feature_type='feature')
datasets = [''] + datasets if datasets is not None else []
for ds in datasets:
	for fc in arcpy.ListFeatureClasses(feature_dataset=ds):
		if ( fc.upper() == fcName.upper()):
			print('Feature Class ' + fc + ' found in ' + ds + ' Dataset')‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Regards,
Leo
