How to Remove Domains in SDE When Domain Owner is Blank?
4745
10-23-2015 09:47 AM
MarkMcCart
I was adding new domains into our Oracle SDE 10.3.1 geodatabase. All was going well until I noticed that the 'Domain Owner' field was missing. Without it it populated, I can't go in and add/delete/modify those codes. Any suggestions on how to assign the domain owner? See attached screenshot.
LitingCui
New Contributor II
Close the ArcMap/ ArcCatalog, and then reconnect, are you able to see the domain owner?
ChrisDonohue__GISP
Adding some of the ESRI Geodatabase experts so they will see this faster:
Jake Skinner
Asrujit SenGupta
Vince Angelo
Chris Donohue, GISP
George_Thompson
Esri Frequent Contributor
Are you receiving any errors when trying to delete them?
Are there any feature classes that are using those domains currently?
Who was the original owner of those domains? Are they still a user in the geodatabase?
Can you try with the geodatabase administrator to delete them?
Here some documentation on removing domains: Delete Domain—Help | ArcGIS for Desktop
Hope this helps......
-George
Managing DataEnterprise GIS
--- George T.
by Anonymous User
Not applicable
What does the following SQL Query return:
select * FROM [GDB_ITEMS] where name like '%CARDINAL%'
Please do not attempt to delete any records from this table or edit any tables in the backend. This query is just for testing.
LitingCui
New Contributor II
deleted-user-uXtLD1BYscf0
New Contributor III
this worked for me. The old close and re-open trick!
