How to increse maximum connection on Geodatabase 10.3
4782
01-28-2015 06:55 PM
khairulamri
Hi All,
in 10.3 I didn't saw ArcSDE Command line tool, seems Esri has converted the command line tool as geoprocessing toolbox.
I'm curious how to increase maximum connection on RDBMS geodatabase in 10.3 version (usually I use ArcSDE Command line tool). is there any geoprocessing toolbox like sdeconfig to alter maximum connections? Please Advice
Thank you
Amri
Tags (1)
AngelaMüller
New Contributor III
Hi Amri,
nn previous releases of the enterprise geodatabase, the default number of connections allowed was 64.  Beginning with 10.3, there is no limitation imposed on the number of connections to new 10.3 geodatabases or geodatabases upgraded to the 10.3 release.
Angela
AngelaMüller
New Contributor III
Hi Amri,
Angela
khairulamri
Thanks heaps Angela,
I confirmed this through sde_server_config table directly, default value for maximum connections on 10.3 is 999999.
Amri
