How to add two tables in Geodatabase view without any join between them?
2161
10-19-2015 07:06 AM
SaidAkif
Hi all
I want to add two tables in geodatabase view (see attached). Those two table can not be related (attributes tables)
I am struggling with the SQL statement
VinceAngelo
Esri Esteemed Contributor
You haven't provided any of the details that would permit us to help you. Among the things missing:
  • The RDBMS (including version)
  • Version of ArcGIS
  • Detailed descriptions of all columns in both tables
  • If the tables have geometry columns, the geometry storage type(s)
  • The column(s) the tables have in common
  • The indexes available on those columns
I always use SQL directly to construct views.
- V
SaidAkif
Sorry!
  • I don't have any Relational database management system software installed on my PC. Since I work in a federal organization, it is had to get a RDBMS software installed in few day. My database is an ArcSDE one managed originally with Microsoft SQL Server management studio which I don't have. So I have to do it with ArcCatalog
Version of ArcGIS
  • 10.1
  • Both feature classes have those fields: FID, Shape, OBJECTID, PARENT_ID, ZONE_ID, BIOME, IUCN_CATEG.
  • I don't know if it is possible to view both tables based on shape field only
  • Polygon
  • As I asked before, it is a possibility to view to tables without any column in common
  • OBJECTID
