How I can shift non-spatial tables into enterperise geodatabase without changing primary key and foreignkeys in sql server?
156
09-25-2017 08:33 AM
Hello everyone, i have two database in sql server 2012. One is enzerprise geodatabase and another is a simple attribute datase. Now i need to shift all the tables of attribute db to geodatabase. I have tried in several ways without changing the Key fields, but i am facing some troubles regarding OBJECTID, Date data type and primary keys and foreign key are not generating. How I can shift all the tables data and schema together?
Already I have shifted tables but there are no pk and fk inside and I cannot avoiding making OBJECTID instead of ID fields (only if I just drag and drop table into geodatabase in arcgis- but those table has not any id will make a objectid). The other problem is no tables now has Date type. I know about datetime2 data type and now i am making newly inside geodatabase new tables, but is it the only solution?
Regards
Muqit
Reply
MVP Regular Contributor
Try using 'Generate Scripts' followed by 'SQL Server Import and Export Wizard'...
SQL Server Data Import – How To Preserve Primary Keys and Identity Fields | Williamsport Web Develop...
How to import tables without losing indexes and keys in SQL Server 2008 - Stack Overflow
This is actually a question for the Microsoft Forums more than an Esri forum...
Reply
