How  create a representation using a subtype and Domain?
3543
02-10-2015 09:07 AM
Hi, i'm working in a Geodatabase, i have a field "SIMBOLO"  is a subtype and is Short Integer, i  want to know
how to create a representation in a geodatabase using subtypes and domains? because i'm not create the field RULEID and OVERRIDE.
thank ¡¡¡¡¡
Reply
Dear Mr. Javier,
I found that you have a feature class and you want to present the feature in many type of symbology using a field "SIMBOLO" that is subtype.
So my humble suggestions are:-
1. Right click on the feature class > properties and go to tab Symbology.
2. Under tab Symbology, go to Categories and under value field set read to field "SIMBOLO"
3. Click to add All Value.
4. To convert to respresentation, right click on the feature class and click at Convert Symbology to Representation.
5. After you make the convert, field RULEID and OVERRIDE will be created automatically.
Good Luck!!
Reply
Dear Mr. Javier,
Good Luck!!
Reply
