Geodatabase Annotation Will Not Stack In Certain Maps
1826
10-15-2015 06:21 AM
My geodatabase annotation looks fine in ArcCatalog, as well as the other maps I've used it in. However, in my new map, I'm having a hard time getting the stacked labels to actually stack. They're appearing in the map like this:
but I need it to look like this:
I've dug around in all the geodatabase properties and can't find anything that addresses this. Any help would be much appreciated! Thanks!
Reply
Hi Clayton,
If your annotation feature is a multi-part feature and has curvature then I believe you'll have to change that before you can stack. This is the workflow that has worked for me...
  1. Right click the annotation feature and "Convert to Single Part"
  2. Right click the annotation feature and select "Curvature" then "Horizontal"
  3. Then edit your text in the Annotation Attribute window by adding an Enter after each word to format it the way you'd like
I hope this helps!
Grant
Reply
