From data table to spatial view
1580
7
05-01-2020 08:48 PM
PamelaLandy
Hi all ,
I have an a table with x, y coordinates in my DB oracle .  that I have an a  GDB on for my spatial side, how can I convert that table to a point layer inside my GDB. I have tried doing a view but it is still a nonspatial datatable when I view it in desktop arcmap
DavidPike
MVP Frequent Contributor
Hi Pamela,
If you go to 'Add Data' and point to your table, it will then get added to ArcMap Table of Contents (TOC) on the left-hand-side.
If you then right click on the table, go to 'Display XY' where a popup will then appear for you to specify your coordinate columns and coordinate system (be very aware of the coordinate system you are using, is it lat long or NAD etc?). when you click 'OK' the data should be displayed spatially in your map frame.
At the moment, that data is only being displayed on the fly and does not 'exist' in a spatial context.  The final step is to right-click on the newly added displayed data in the TOC and --> Data --> export Data to save it as a shapefile (.shp) or a feature class within a GDB.
PamelaLandy
Hi Dave , It is a possibility but in postgres I have seen that through a line like this in the view , it is possible to give it the spatial reference
st_point((table.attrlong)::double precision, (table.attrlatt)::double precision, 4326) AS shape
Although I already configured the libst_shapelib.so library I am still looking for the same in oracle.
DavidPike
I've not implemented it myself but
Spatially Enabling a Table
Looks promising.
by Anonymous User
Not applicable
Hi Pamela
You can use sde.st_point or sde.st_geometry for creating the spatial view. Make sure you add anumeric unique identifier (similar to an OBJECTID field).
You can also try "Make query layer" from ArcGIS Desktop, but this do not create the view in the database, so in the mxd...
Regards
Jesús de Diego
PamelaLandy
Hi Jesus , Do you have an example or reference for how to generate a spatial view from a table ( points coord(x y) ) using the sde.st_point or sde.st_geometry in oracle.
Thanks in advanced
MatthewCarey
Hi Pamela, here's an example based on one that's worked for me:
CREATE OR REPLACE FORCE EDITIONABLE VIEW "SCHEMA_NAME"."VIEW_NAME" ("ID", "SHAPE", "JOB_NUMBER") AS
SELECT ID, sde.st_geometry(device_longitude,device_latitude,null,null,4326) SHAPE, JOB_NUMBER
FROM the_source_non_spatial_table;
Database people will have to excuse me if the syntax is poorly done, I'm a bit of an amateur at it.
I guess you can do a similar thing in an Insert or Update statement to make it a permanent point feature class. When you do that you're supposed to create the ObjectID the right way, there's a reference here:
How To: Populate an ArcSDE maintained row ID column when inserting a new ST_Geometry feature with SQ...
Hope this helps!
Matt
CraigSwadner
Select * into tablename from view
Craig Swadner (GIS Coordinator)
City of Cape Coral
1015 Cultural Park Blvd.
Cape Coral, Fl 33990
Did you know the best way to report issues to ITS is to use the Service Desk system? This will ensure someone in ITS gets your request and allows us to track the progress. Please enter all your issues and/or questions by clicking https://breeze.cape.capecoral.net
