Flow Direction does not show in new digitized lines
673
10-16-2020 05:43 AM
JoseSanchez
Hello everyone,
Environment:  ArcGIS 10.7, ArcSDE 10.7 in a Ms SQL Server database.
We set up our geometric network with  Flow direction  "With Digitized Direction". After running the tool, the whole Geometric Network had a direction.   Now when we digitize new lines with the regular editor tool, we do not see the flow direction represented in the new lines, it shows as UnInitialized . Is there anything else we have to do in ArcMap  to see flow direction in new digitized lines.
# Process: Set Flow Direction
arcpy.SetFlowDirection_management(SewerNetwork, "WITH_DIGITIZED_DIRECTION")
George_Thompson
Esri Frequent Contributor
It looks like you may have to set it when you add new features; About setting flow direction—ArcMap | Documentation
You must set flow direction whenever you do the following:
I am not sure if it does it on-the-fly or live.
--- George T.
JoseSanchez
Hi George
In our case we added features to the geometric  network.
This same links says  that "You can use ArcMap … to maintain flow direction in your geometric network"
But I do not understand how. Is there a tool in ArcMap to run the  "Set Flow Direction", after an editor adds additional points or lines?
In our environment a regular editors  performs these operations:
 - Add or remove features from the network.
- Post and Reconcile from his/her child version to QA version
So as part of the editor tasks we need to include a  "Set Flow Direction"
How can we do that?
George_Thompson
Here is the link to Setting the flow direction—ArcMap | Documentation . You could also have them run the GP tool you reference in the OP; Set Flow Direction (Data Management)—ArcMap | Documentation
--- George T.
