Export of a single Oracle GIS table and import into a different table name
920
06-08-2018 03:59 AM
by Anonymous User
Not applicable
Hi I am after the syntax to export and import a single GIS Oracle 9i table from 'live' to 'test' as part of our migration to ARC.
We currently dump the entire database out via a scheduled task as per below:
del e:\dumps\dev_sswdnet.dmp
exp SSW/****@DNET tablespaces=(GIS_DATA,GIS_ARCHIVE,GIS_INDEX) LOG=E:\Dumps\SSW_EXP.LOG FILE=DEV_SSW.DMP
Does anyone know how just to specify to export JUST the data in a single table from  sdf_asset_all.
I also need help with the import script if this is ok to ask
by Anonymous User
Not applicable
i have cracked the export
exp SSW/***@DNETTEST tables=(SDF_ASSET_ALL) LOG=E:\Dumps\SSW_EXP_SDF_ASSET_ALL.LOG FILE=DEV_SSW_SDF_ASSET_ALL.DMP
I now need to construct an imp script to take this data into a new table called SDF_ASSET_ALL_REPORTING rather than SDF_ASSET_ALL
Asrujit_SenGupta
MVP Regular Contributor
Check these: REMAP_TABLE  & using the remap_table import option
However, this rename will work during the import. Not if the table already exists.
by Anonymous User
Not applicable
will this work with a straight imp script not a impdp
imp ssw/***** tables=(sdf_asset_all) remap_table=sdf_asset_all_reporting
Asrujit_SenGupta
Why not just create a copy of the Table in the main database with whatever name you prefer, Export that out, import it in your test environment and then drop the copy in the live environment. That's way easier..
https://www.techonthenet.com/oracle/tables/create_table2.php
CREATE TABLE New_Table_name AS SELECT * FROM Existing_table_Name;
