I am receiving this error while clicking on the lock tab in Geodatabase Administration using ArcCatalog 10.5.1. Has anyone else experienced this?
Solved! Go to Solution.
Thanks Bill. Was hoping someone heard what the actual "Fix" is.
NULL shows that there's something amiss in the tables. I'm really hoping the fix isn't hiding that error. Could change from a minor/moderate problem to catastrophic. Especially if the true issue is identified after weeks or months.
Interesting that, when I use ArcMap 10.5 I don't see the issue, but when I use ArcMap 10.6.1, I do.
yo-yo bug
Well, I think the locks were in the table since Dec 2018, just not reported by the 10.5 version of the Desktop software. Now that it's reporting by 10.6.1, it's an issue because I can't view locks and administer the database through the Desktop client.
Can you update to desktop 10.7?
I am on 10.6.1 and still having this annoying problem... has it ever been resolved?
I am also experience this with 10.6.1. If we delete all the records out the tables listed above, then it solves the issue. Would be great to know the cause of the problem so we can try to prevent it.
Is this issue occurring with all enterprise db versions or just specific types of enterprise dbs (SQL Server)? My org utilizes Oracle so I am curious if I will encounter this bug.
For us, we run SQL Server 2016 Enterprise and SDE 10.6.1. This has never happened in our Oracle or Postgres databases.
