Editing default with version view (evw - multi-version view) in sde with many versions
1042
09-29-2021 12:14 PM
forestknutsen1
MVP Regular Contributor
Is there any risk in editing the default version with an multi-version view (evw) in an sde environment?
  • We have a number of batch jobs that update default version attributes with sql and the evw
  • Database is Oracle
  •  We have a high number of versions within the database, ~900. All of the versions have default as parent
forestknutsen1
Bumping this one up...
Steve_Salas
If the changes impact a signifcant number of records that are likely to be edited in those existing versions, I'd be prepared for conflicts arising during the reconcile process.  Sure you can automatically resolve conflicts in favor of _______ version, but I don't think it will differentiate between conflicts with your SQL update against the EVW vs. conflicts created by a different version being posted.  Those are the factors I would look at without knowing much else about your data & workflow.
forestknutsen1
Thanks Steven.
Right. The fields in question only get edited by the evw jobs and they are mostly static values, i.e. once set they are unlikely to change. So, I think the conflicts will be low.
