Domain in Field Properties vs Subtype Domain Properties
102
04-25-2018 05:42 PM
MVP Regular Contributor
I notice that when I set all the subtype domain fields to a new domain the field properties (from a right click on the head of a field in a attribute table is not updated with the new domain. However, I can use the domain geoprocessing tools to remove and assign the new domain. I am wondering:
1) Is this normal behavior
2) Should I be concerned that the field properties is out of sync with the subtype properties.
Maybe I should just remove the domain from the field properties and leave it blank with the domain goeprocessing tools. It feels like more intuitive behavior would be to have the software make a note in the field properties to see the subtype properties because the field to domain is could be a one to many relationship once subtypes are implemented.
Reply
