Does migrating an Oracle database break services already published to the ArcGIS Server?
160
12-13-2017 05:55 AM
New Contributor III
Our IS department needs to migrate our Oracle geodatabase off of a Windows 2003 server. This will alter our TNSNAMES.ORA file. Will this cause issues with our services that have already been published to our ArcGIS Server from the geodatabase?
Reply
Occasional Contributor III
Hi Shannon - This is the beauty of TNS Names. As long as the ArcGIS Server gets the update TNS File you'll be good to go. Ideally run this in a test/staging environment first, but I've been through this type of migration many times with no problems.
Adam Z
Adam Z
