Create Role Error
200
05-20-2020 08:45 PM
MahmoudHegazy
Create Role Error
I'm trying to Create Role with mutiuser geodatabase  [Operation succeeded with warning messages written to error log file]
Error creating role.
Failed to execute (CreateRole).
MarcoBoeringa
MVP Regular Contributor
Maybe a stupid question, but do you have database privileges to create roles? Enterprise databases like Oracle, PostgreSQL and SQL Server offer fine grained access to privileges for doing things on the database. Unless your DBA permitted creating roles, the Create Role tool might fail. This is something out of control of ESRI and must be handled by your DBA.
MahmoudHegazy
Thanks for your replaying iam using sql server so do you have any solution
MarcoBoeringa
The first step is to review the permissions / priviliges your current login / user has, to check if you are allowed to create roles. If you have, then it may be time to contact ESRI support.
