Create a DNS file to connect an oracle db to access
1327
04-10-2019 07:54 AM
BrandonPrice1
Hello:
What is the proper format and the information that is needed? I am trying to connect to this:
"G:\Database Connections\eGIS_Cadastral on EGISDBP1 as viewer.sde"
These are the connection properties:
ArcGIS Server on Microsoft Azure
BrandonPrice1
I meant to say sql server db in the header
BrandonPrice1
sorry
George_Thompson
Esri Notable Contributor
Here are the connection parameter needed: https://desktop.arcgis.com/en/arcmap/latest/manage-data/gdbs-in-sql-server/connect-sqlserver.htm
Are you getting an error?
--- George T.
