Could you help with importing numpy and arcpy on Pycharm?
1508
13
02-03-2019 10:34 PM
TshepoHlako
New Contributor II
I'm struggling with running/importing 'numpy and arcpy' on pycharm, which points to python.exe in the Python 27 directory where ArcGIS 10.4 is installed. How else can i try importing the two modules as it gives the errors "ImportError: No module named arcpy" for both arcpy and numpy.
Charlie
FrédéricPRALLY
Hi Charlie,
Are you using a 32-bit environment about PyCharm?
I'm not using PyCharm actually, I use PyScripter to debug ArcPy code. So I've installed a PyScripter 32-bit and nor 64-bits versions.
A trick to identify your 32 or 64 bit environment is to jump on Python Console. You must have :
Python 2.7.14 (v2.7.14:84471935ed, Sep 16 2017, 20:19:30) [MSC v.1500 32 bit (Intel)] on win32. ***
Regards,
Fred
TshepoHlako
New Contributor II
Thanks Fred, it seemed to be running from another version of python that i had on the machine, 3.7 I'm now trying to fix that.
JoshuaBixby
MVP Esteemed Contributor
I regularly use PyCharm with ArcMap's and ArcGIS Pro's bundled Python interpreter.  In the settings, what do you have defined for the Project Interpreters?
TshepoHlako
New Contributor II
Hi Joshua, my Project Interpreter points to "Drive:\Python27\ArcGIS10.4"
JoshuaBixby
Is "Drive" literally what is says, or is it referring to C:, D:, or some other drive?
TshepoHlako
New Contributor II
That is referring to whether it's C:, 😧 etc.
DanPatterson_Retired
If you have control over your machine...
/blogs/dan_patterson/2018/12/28/clone
/blogs/dan_patterson/2018/12/13/spyder
Spyder, IPython and the Jupyters are all distributed with the Anaconda distribution of Python and hence ArcGIS Pro
TshepoHlako
New Contributor II
Hi Dan,
Unfortunately, i've no control over the machine, its used by other colleagues besides myself. Thanks
You can try the 'Clone' option then
