Copying SDE View Add field "OBJECTID_1"
474
06-05-2018 08:18 AM
JoseSanchez
Occasional Contributor III
Hello everyone
We create SDE spatial views using ArcCatalog in version 10.2 and 10.4, and when we copy an sde views to another SDE database the resulting feature class gets a new field "OBJECTID_1".
This behavior only happens since we create SDE views with ArcCatalog in 10.2 and 10.4. The old way of creating SDE views with “sdemon” command line worked fine when copying a SDE views to a new SDE database, it did not add any extra field.
Any suggestions to eliminate this field?
JoshuaBixby
MVP Esteemed Contributor
What tool are you using to copy?
JoseSanchez
ArcCatalog or Python script arcpy.Copy_management
JoshuaBixby
I know that Feature Class to Feature Class or Table to Table allow for field mappings, which would allow you to drop the old OBJECTID_1 field, but I can't recall if those tools work with a spatial view as the input.
