Copy parallel not preserving attributes and also crashing at times
1888
02-08-2016 09:13 AM
TimLangner
Hi there
I'm trying to copy a road centre line so that I have a left and right footway. This is in a file geodatabase but the centre road lines come originally from an ArcSDE database.
To do this I am using copy parallel as it needs to be linked to an Excel Spreadsheet and representations only work with feature classes.
Previously I had managed to do this. Today I was about to do the right hand side and create a feature class with the attributes preserved.
However when I tried to do the same to the left hand side I could not get the attributes to come across.
As soon as I select more than one line, the option, Treat section as a single line is greyed out. However if it's not possible to have this option available when select multiple lines,  how come I was able to get the right hand side to be created with the attribute information intact.
I am using ArcMap 10.0 but I tired it in version 10.3.1 and I'm having the same issues.
Also ArcMap 10.0 kept crashing without errors. I think the issue occurs when a line length becomes less than 0. I found this didn't occur in version 10.3.1 and I actually got an error message. Although that didn't explain what was causing the issue. However at least I didn't need to restart ArcMap, which at times can be a slow process on my computer. I was thus able to find the offend row and deal with it manually. However the attributes issue was still present for everything else.
Thanks for your help
Tim
