Connect to a file geodatabse in MS Access?
2855
10-16-2023 11:20 AM
Labels (3)
AlfredBaldenweck
MVP Regular Contributor
Bit of a reverse of a common question.
Is it possible to connect a file GDB to MS Access, either to feed data or to use it as an interface?
It seems like Access doesn't recognize file GDBs by itself, but I was thinking maybe using ODBC?
Develop an ODBC driver for the esri File Geodataba... - Esri Community
There was also this question, where someone says it'd be possible to make one using the API, but not sure if anyone ever did that FGDB ODBC driver? - Esri Community
MarceloMarques
Hello @AlfredBaldenweck
You will find the answer to your questions and a lot more details in this ArcGIS Blog article.
It's Not Personal: A quick history of the geodatabase and why personal geodatabases are not in ArcGI...
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
AlfredBaldenweck
Thank you for the response, however, that is the answer to the opposite question of what I asked, which is about using file GDBs in Access, not about using Access files in Pro.
MarceloMarques
There is no ODBC driver for file geodatabases therefore is not possible to integrate file geodatabases with Access out of the box and you will need to create some custom tool to be able to do this.
MarceloMarques
You can explore alternatives like Safe Software FME Workbench and ArcGIS Pro Data Interoperability Extension to read file geodatabase data and synchronize data with an Access Database.
FME Transformer Reference Guide (safe.com)
List of Readers and Writers (safe.com)
ArcGIS Data Interoperability extension for Desktop—ArcGIS Pro | Documentation
