Cannot open feature class in a GDB, "Error opening feature class. General Function Failure"
1556
10-19-2019 04:12 PM
Liliaaaaaa
New Contributor III
Hi mates,
I have a feature class in my GDB but I cannot open it now, with the error message "Error opening feature class. General Function Failure", like screenshot below.
I cannot load the data to ArcCatalog or ArcMao anymore, could you please help?
George_Thompson
Esri Frequent Contributor
Is this in a file or enterprise geodatabase?
Any other feature classes have the same error message when added to the desktop client?
Can any other users add the same data?
--- George T.
RobertBorchert
Frequent Contributor III
in arc catalog create a model that will export the featureclass as a shape file
export the model as a python script.
Run the script and see if you can open the shapefile.
if it works you can rebuild the faulty feature class in your database from the shape file
