Cannot able to upgrade arcgis server 10.0 to 10.3?
4153
12
02-10-2016 05:21 AM
SadanandacharB1
Hi All,
       I am trying to upgarde from arcgis server 10.0 to 10.3,
While doing this i am getting error like below, Please help me on this issue.
[Wed Feb 10 18:25:51 2016] DB_open_instance()::db_connect (OCI8) error: 12560
[Wed Feb 10 18:25:51 2016] Error: Underlying DBMS error (-51).
[Wed Feb 10 18:25:51 2016] Error: DB_arcsde_setup: Unable to connect
[Wed Feb 10 18:25:51 2016] ORA-12560: TNS:protocol adapter error
[Wed Feb 10 18:25:51 2016] ERROR installing/upgrading ArcSDE, Error = -51
Here i have both oracle 64-bit client and 32-bit oracle client and i am able connect from ArcCatalog,
But when i tried to upgarde it is giving this error? Please please help me on this issue
SadanandacharB1
Hi Vince Angelo,
Answer to question 5 is NO. Can't we upgrade the 10.0 sde database to 10.3  if oracle version is 11.2.0.1.0?
VinceAngelo
Esri Esteemed Contributor
No, 11.2.0.1.0 is not a supported Oracle release.  The minimum is 11.2.0.3.0, and an up-to-date build, security-wise, would be 11.2.0.3.15.  You must upgrade the database before upgrading the enterprise geodatabase components.  The Oracle client library should be at the same (or later) release as the server.
SadanandacharB1
Thank you Vince Angelo, I will upgrade the database first and try to upgrade the geodatabase components.
Thank you so much once again for your  valuable support
