can no longer edit files in SDE
868
07-29-2014 12:12 PM
RudyCharlot
Hi all,
I am using 10.0. I recently started having problem to edit files that are in the SDE database. I am not sure what happened, I was building a cached map to be used in Lucity dashboard for my stormwater field crew. A few days later when I try to edit any of the files in the SDE database I get an error message which I don't believe this error message has anything to do with what I was doing as far creating the cached map. Please see attached file. I have checked all different avenue to see how I can fix the problem I ended up with a negative result. We are not using Version now, but the error message suggests that the files I am trying to edit are Resgister  As Versioned that have to be Unregister As Versioned before I can edit the files. I have unchecked the box that is under Editor, Option, and General, but nothing happened. Remember, I have the owner privilege access in the SDE database. Any idea on how to fix this problem?
Best regard,
Rudy
RudyCharlot
I am using ArcInfo. But I think I figured it out this past Friday. What I did was from ArcCatalog, showing below, I dragged "Unregister As Versioned" into ArcCatalog when finished I right clicked on the Feature Dataset that I want to Unregister As Versioned. Then I click the "Plus sign " to the left of the Feature Dataset and then left click the Feature Dataset to un-greyed the "Unregister As Versioned" tool. In addition, I right click on the Feature Dataset and click the Unregister As Versioned tool and click "OK" to run the tool and "voila" . It is all done in ArcCatalog.
Thank you very much for all your help on this matter.
Best regards,
Rudy Charlot
CoryMacNeil1
Occasional Contributor II
Hi Rudy,
Have you tried editing the data in a new map document?  If it is the same map document, it may be corrupt.  Sometimes I find copying your layers and pasting them into a new map document can solve small problems.  Annoying, but can work.
If you right-click on one of the feature classes in your enterprise geodatabase connection (with admin rights), is the Register as Versioned... option available?  What about the Unregister as Versioned... ?  Have you tried registering the feature classes and then unregistering?
RudyCharlot
Thank you for getting back with me on this matter.
I have tried the one you mentioned on the first paragraph below, but the
one on the second paragraph I can try it as soon as possible to see if that will work.
Thanks again for your respond and I will let you know how it went.
Sincerely,
Rudy Charlot
RobertScheitlin__GISP
Rudy,
   You are using the correct license for editing SDE data right, i.e. ArcEditor or ArcInfo License.
RudyCharlot
Best regards,
Rudy Charlot
