ArcMap 10.5 freezes when saving edits to feature class in a file geodatabase
1153
01-11-2018 12:53 PM
JohnLambert
I'm encountering a very peculiar bug in ArcMap 10.5. I have an mxd I created as part of a large project, and when I attempt to save edits to a feature class from the project's file geodatabase ArcMap freezes every time. Initially I suspected that either my mxd or geodatabase had been corrupted, but I can successfully save edits to shapefiles from different directories in the same mxd AND save edits to feature classes from the same geodatabase in different mxd's. Perhaps it's something about the particular combination of layers that are added to the dataframe? I really don't know. Everything is in the same projection and I haven't encountered errors running any other tools or processes. Without success, I've tried:
  • clearing the geoprocessing history and image cache
  • compacting the geodatabase in ArcCatalog
  • running MXD Doctor on the map file
  • copying the geodatabase and changing the data source to the backup
  • copying the data frame from the original mxd to a new map and editing in that window
  • whitelisting the directory the geodatabase is stored in in my antivirus (Windows Defender)
Any ideas would be much appreciated. Thanks!
DanPatterson_Retired
create a new geodatabase and copy the features to it, but don't do this in the existing problem that you are having problems with
Robert_LeClair
Esri Notable Contributor
Something else to try - rename the ESRI folder in the C:\Users\<user profile>\AppData\Roaming and  C:\Users\<user profile>\AppData\Local to ESRI_old.  You'll lose any ArcMap customization you've done but it will reset ArcMap.
