I've been working with UPDM 2018 and untools 2.2 successfully for some time. Today, I upgraded to 2.3.0, and AssetPackageToUtilityNetwork is crashing. The first crash gave this error:
ERROR 001959: No valid asset type was found. [Excess Flow Valve/Automatic Reset]
Failed to execute (SetSubnetworkDefinition).
I tried running it again, and got this error:
Item Field OID Value Message Level
0 None None PipelineDevice-8 | PipelineDevice-17 | PipelineDevice-15 | PipelineDevice-19 | PipelineDevice-20 | PipelineDevice-16 | PipelineDevice-5 | PipelineDevice-18 | PipelineDevice-2 | PipelineDevice-12 | PipelineDevice-3 | PipelineDevice-13 | PipelineDevice-1 | PipelineDevice-9 | PipelineDevice-11 | PipelineDevice-4 | PipelineDevice-10 | PipelineDevice-6 AssetType domain is used in multiple places. error
What's up? Do I need to uninstall Pro 2.3 and go back to 2.2?
Solved! Go to Solution.
I've successfully pinpointed the cause of the crash originally reported: it will occur if I take the UPDM asset package and add a many-to-many relationship class between PipelineAssembly and PipelineDevice, as below:
sRelClassName = "UNSGPipelineAssembly_PipelineDevice"
arcpy.CreateRelationshipClass_management(
"PipelineAssembly", "PipelineDevice", sRelClassName,
"SIMPLE", "Device", "Assembly", "NONE", "MANY_TO_MANY", "NONE",
"GLOBALID", "ASSEMBLY_GID", "GLOBALID", "DEVICE_GID")
arcpy.AddGlobalIDs_management(sRelClassName)
self.AddEditorTracking(sRelClassName)
I'm attaching a second asset package with that modification. In the meantime, I should be able to work around this issue by creating the relationship class after the asset package is applied, rather than going back to untools 2.2.0.
Can you provide the asset package? You can email to pleblanc@esri.com
It's too big to email. Can you email me a temp FTP login, or do I need to start a tech support session?
Send me an email and I can provide you a link.
Here's the link to UPDM 2018:
I also attached a UPDM asset package to my original post.
I followed your advice and tried it on a new database. No errors. Apparently I'm not vacuuming the GDB as cleanly as I could.
FYI, the Naperville sample gas data asset package is also failing.
The asset package has the following errors:
0 B_Subnetwork_Diagrams diagram_template 1 Basic Diagram template does not exist error
1 B_Subnetwork_Diagrams diagram_template 2 Basic Diagram template does not exist error
2 B_Subnetwork_Diagrams diagram_template 3 Basic Diagram template does not exist error
3 B_Subnetwork_Diagrams diagram_template 4 Basic Diagram template does not exist error
4 B_Subnetwork_Diagrams diagram_template 5 Basic Diagram template does not exist error
5 B_Subnetwork_Diagrams diagram_template 6 Basic Diagram template does not exist error
6 B_Subnetwork_Diagrams diagram_template 7 Basic Diagram template does not exist error
The plot thickens: I reverted one of my environments to Pro 2.2.4, and untools 2.2.2 also doesn't like my asset package [I got a bunch of bad field name errors, which I forgot to save]. I had to go back to untools 2.2.0 [which I've been using all along] in order for it to apply without errors.
Each release of untools adds more validation. Those error messages are expected.
Where's the documentation?
I don't see it here:
Apply Asset Package—Tool Reference | ArcGIS Solutions
Release notes for 2.3—Get Started | ArcGIS Solutions
I would like to know what to expect.
