UN Model for Water
1860
03-02-2020 09:38 AM
SrinivasaRao1
We are in the last process of UN model for water and we found error while processing enable topology tool, could any one suggest how this can be fixed and attached is the snap shot for your quick review. Data was processed by using ESRI UNdata.. not sure why the error was seen if the data is clean,
PaulLeBlanc1
Once you register your data as versioned, the "ONLY_ERRORS" option is invalid. If you want to use it, you'll have to unregister your data (or use "ENABLE_TOPO").
JohnAlsup
Check your connection type for your database connect.  I suspect it's using traditional versioning
John Alsup
jalsup@esri.com
SrinivasaRao1
By default it was set to Branch so this only
we kept and for your reference, attached is the screen by default when we start versioning.
PaulLeBlanc1
