I’m trying to use .NET SDK to perform Electric Downstream Trace via Add-In.
1163
07-14-2020 02:53 PM
RajeshPaulraj
I’m trying to use .NET SDK to perform Electric Downstream Trace via Add-In. Add-In will display a form window with parameters. Based on the user selection Electric Downstream Trace should be performed and the devices should be returned as results.  If anyone had implemented this then can you please share the code snippet or the steps that should be followed?
Rajesh
RichRuh
Hi Rajesh,
Have you seen this sample: arcgis-pro-sdk-community-samples/UtilityNetwork/LoadReportSample at master · Esri/arcgis-pro-sdk-com...
If you have specific questions, I'd recommend posting them in the Pro SDK space.
--Rich
