Are you ready for the Utility Network?
3092
19
12-14-2016 09:39 AM
NicolasGonzalez
As we gear up for the Beta release of the Utility Network we want to keep you informed of the latest information.
Sign up now to get the latest news on the Utility Network and get a free copy of “The Road Ahead for Network Management” White Paper. Once signed up, you will also receive updates from our Road to Utilities Network Newsletter.
Hear the latest, here.
RobertBorchert
Honored Contributor
to be honest. Saw the webanar the other day. probably never going to touch it.
BrianBaldwin
Anything we could help you understand or clarify Robert?
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
forestknutsen1
MVP Alum
Where do we sign up?
BrianBaldwin
Things have moved forward quite a bit since this post from Nydia. I would suggest take a look at the status of the actual tools here:
Configurations and Deployment Tools
Another spot with some great documentation is simply the ArcGIS Pro Help site, specifically:
ArcGIS Pro Help - What is a utility network?
forestknutsen1
MVP Alum
Okay, thanks
RobertBorchert
Honored Contributor
It would be handy to be able to see a diagram or better yet the data model to be used.
BrianBaldwin
Here are the electric distribution and transmission models:
What is the electric data model?—Help | ArcGIS for Electric
The PNGs are print quality as well. So open them up in a new window and download to get the full resolution copy.
RobertBorchert
Honored Contributor
I was hoping for something more along the lines of attributes, domains.
We know what the Electric Distribution devices are but what are the attributes available for
Arresters, Fuses, Transformers.
Where are Reclosers?  Or would those be generalized under Power Factor Correcting Equipment.
BrianBaldwin
Here you go Robert: Electric
This is the data dictionary for the out of the box utility network configuration. We believe fully that customers/partners will take this base model and extend it when/where needed.
