What part of ArcGIS do these docs pertain to? "SQL for reporting and analysis on file geodatabases"
2944
12-07-2022 12:24 PM
Bud
Esteemed Contributor
Regarding the docs: SQL for reporting and analysis on file geodatabases
What parts of ArcGIS does the syntax in that page pertain to? For example, where in ArcGIS can we use INNER JOIN in FGDB SQL?
I can see that the word "reporting" is in the title. But I can't help but wonder if that SQL syntax would apply to all FGDB SQL in ArcGIS, including geoprocessing SQL expressions, and not just reporting.
The page makes several references to ArcObjects. So, my questions are:
  1. Can we use that SQL in SQL expressions in GP tools like Select By Attributes?
  2. Or is that SQL limited to the FGDB .NET SDK? (I'm not sure about that terminology; this isn't my area of expertise)
  3. Should the title of that page be changed to SQL for reporting and analysis on file geodatabases (ArcObjects)?
  4. Or do those docs apply to some other part of ArcGIS?
Thanks.
Bud
