Enhanced Measurement Widget
317
3 weeks ago
Brian_McLeer
Enhanced Measurement Widget for ArcGIS Experience Builder
Overview
This custom widget provides comprehensive measurement capabilities for ArcGIS Experience Builder applications. The widget was built on ArcGIS Experience Builder Developer Edition 1.18. The widget supports eight measurement tool types with extensive configuration options and export functionality. End users can create measurements and export them in multiple formats.
This is the first release of the widget and should be considered a beta version. Users are encouraged to provide feedback on bugs, requested enhancements, or suggested changes through comments on this post.
Required Dependencies
Before implementing this widget, install the following npm packages:
npm install @turf/turf
npm install jspdf
These dependencies provide geometric calculation functionality (Turf.js) and PDF export capabilities (jsPDF).
Developer Configuration (setting.tsx)
The setting.tsx file provides developers with a comprehensive configuration interface within Experience Builder. The configuration is organized into multiple sections that control widget behavior and appearance.
Map Connection
Developers select which map widget the measurement widget will interact with using the MapWidgetSelector component. This establishes the connection to the map view where measurements will be drawn.
Measurement Tools Configuration
The widget supports eight measurement tool types:
  • Point measurement (coordinate display)
  • Distance measurement (linear distance)
  • Area measurement (polygon area)
  • Circle measurement (radius and area)
  • Rectangle measurement (dimensions and area)
  • Triangle measurement (dimensions and area)
  • Freehand polyline (drawn distance)
  • Freehand polygon (drawn area)
Each tool can be individually enabled or disabled. Developers can configure:
  • Default tool selection on widget startup
  • Auto-start behavior to activate the default tool immediately
  • Continuous drawing mode for repeated measurements without tool reselection
  • Auto-clear behavior when switching between tools
Unit Configuration
Default measurement units are configurable for:
  • Linear units: meters, kilometers, feet, miles, yards, nautical miles
  • Area units: square meters, square kilometers, square feet, square miles, acres, hectares
Users can change units at runtime, but developers set the initial defaults.
Segment Labeling
For polyline and polygon measurements, segment labeling can be enabled to display individual segment distances. Configuration options include:
  • Enable/disable segment labeling feature
  • Default visibility state for segment labels
  • Auto-save segments option
  • Customizable segment label prefix (default: "Seg")
  • Segment label font size (8-24px range)
Display Features
Toggleable features that developers can enable:
  • Statistics panel showing count, total distance, and total area across all measurements
  • Tooltips during active drawing
  • Snapping to vertices and edges
  • Live measurement display while drawing
  • Total distance display for polyline measurements
Each feature includes a configurable default state (enabled/disabled on startup) and visibility toggle option (whether users can change the setting).
Coordinate Display
Coordinate format options include:
  • Decimal Degrees (DD): 34.0522, -118.2437
  • Degrees Minutes Seconds (DMS): 34°03'08"N, 118°14'37"W
  • Degrees Decimal Minutes (DDM): 34°03.133'N, 118°14.622'W
Developers can set the default format and configure whether coordinates display in Web Mercator or the map's spatial reference.
Import/Export Configuration
Export functionality supports four formats:
  • JSON: measurement data with geometry and metadata
  • CSV: tabular data with coordinates and measurements
  • GeoJSON: standardized geographic data format
  • PDF: formatted document with measurement summary
Developers can customize button text for import and export operations and configure default export format.
Symbol Styling
Symbol appearance is fully configurable:
  • Point symbol size (4-32px)
  • Line width (1-10px)
  • Polygon outline width (1-10px)
  • Fill opacity (0-100%)
  • Color palette: 10 customizable colors for different measurement types
Label Customization
Measurement label appearance can be configured:
  • Font size (8-24px range)
  • Label position (center, top, bottom)
  • Label background color
  • Label text color
  • Label visibility controls
User Interface Customization
Developers have extensive control over the UI:
  • Button layout: 2-column, 3-column, 4-column, or vertical
  • Compact mode for space-constrained layouts
  • Always show button text option
  • Show/hide widget title
  • Custom widget title text
  • Show/hide hint messages
  • Show/hide Clear All button
  • Show/hide icons on buttons
  • Custom text for empty state message
  • Custom measurements header text
Tool Button Text Overrides
Every measurement tool button has customizable text:
  • Point tool button
  • Distance tool button
  • Area tool button
  • Circle tool button
  • Rectangle tool button
  • Triangle tool button
  • Freehand line tool button
  • Freehand area tool button
Additional button text overrides include:
  • Clear All button
  • Undo button
  • Redo button
  • Show/Hide Statistics toggle
  • Show/Hide Segment Labels toggle
  • Show/Hide Tooltips toggle
  • Show/Hide Snapping toggle
  • Import button
  • Export All dropdown text
Dialog Customization
Confirmation dialogs have configurable text:
  • Clear All dialog title
  • Clear All dialog cancel button text
  • Clear All dialog confirm button text
Toggle Display Configuration
Developers can configure which toggle controls are visible to end users:
  • Show Statistics toggle
  • Show Segment Labels toggle
  • Show Tooltips toggle
  • Show Snapping toggle
Reset Functionality
A "Reset All Settings to Defaults" button allows developers to quickly restore all configuration options to their default values during development.
End User Functionality (widget.tsx)
The widget.tsx file implements the runtime functionality that end users interact with in published Experience Builder applications.
Measurement Tools
Users access measurement tools through a button grid. The active tool is highlighted, and clicking a tool button either activates it or deactivates it if already active. Tool functionality:
Point Tool: Single click places a point. Displays X,Y coordinates in the configured format and coordinate system.
Distance Tool: Creates polyline measurements. Each click adds a vertex. Double-click completes the measurement. Displays total distance and optionally shows individual segment distances with labels.
Area Tool: Creates polygon measurements. Click to add vertices, double-click to close the polygon. Displays total area and perimeter. If segment labeling is enabled, shows distances for each edge.
Circle Tool: Click to set center point, drag to set radius, click again to complete. Displays radius, diameter, circumference, and area.
Rectangle Tool: Click to set first corner, drag to opposite corner, click to complete. Displays width, height, perimeter, and area.
Triangle Tool: Three clicks create a triangle. Displays three side lengths, perimeter, and area.
Freehand Polyline: Click and drag to draw freely. Displays total distance. Release completes the measurement.
Freehand Polygon: Click and drag to draw freely. Release automatically closes the polygon. Displays area and perimeter.
Live Measurement Display
While actively drawing, a live measurement value appears at the cursor showing the current measurement in real-time. This provides immediate feedback before completing the measurement.
Unit Conversion
Each measurement includes dropdown controls to change display units without redrawing. Distance measurements can convert between all configured linear units. Area measurements can convert between all configured area units. Unit changes apply immediately to the displayed values.
Measurement Management
Completed measurements appear in a list below the tools. Each measurement entry shows:
  • Measurement type icon
  • Timestamp of creation
  • Primary measurement value with unit selector
  • Expand/collapse control for additional details
Expanded measurements display:
  • All calculated values (e.g., for circles: radius, diameter, circumference, area)
  • Coordinates (start/end points or vertices depending on geometry type)
  • Segment details for polylines and polygons
  • Export dropdown for individual measurement export
Segment Labels
When segment labeling is enabled, polyline and polygon measurements display individual segment distances directly on the map. Each segment shows:
  • Segment identifier (e.g., "Seg 1", "Seg 2")
  • Distance value with units
Segment labels remain visible and update if measurement units are changed. The expanded measurement panel lists all segments with start/end coordinates.
Statistics Panel
When enabled, the statistics panel displays aggregate information:
  • Total count of all measurements
  • Combined total distance from all polyline measurements
  • Combined total area from all polygon measurements
Statistics update automatically as measurements are added or removed.
Coordinate Display Modes
Point measurements and polyline/polygon vertex coordinates can display in two modes:
  • Web Mercator coordinates (WKID 3857)
  • Input spatial reference (map's coordinate system)
Users toggle between modes using a coordinate system selector. The widget handles transformation between coordinate systems automatically.
Undo/Redo Functionality
The widget maintains a history of all measurement operations:
  • Add measurement
  • Delete measurement
  • Modify measurement (unit changes, coordinate system changes)
Undo and redo buttons appear in the toolbar when history is available. History persists during the session but clears when the application is closed.
Import Functionality
The Import button opens a file selector. Supported import formats:
  • JSON: imports measurements with full metadata
  • GeoJSON: imports geometric features, creates appropriate measurement types
The widget validates imported data, transforms coordinates to the map's spatial reference if needed, and adds measurements to the list. An import success dialog displays the number of measurements imported.
Export Functionality
Users can export measurements individually or all at once. Export formats:
JSON Export: Creates a JSON file with complete measurement data including:
  • Measurement type
  • Geometry coordinates
  • Calculated values
  • Units
  • Timestamp
  • Metadata
CSV Export: Generates a tabular CSV file with columns for:
  • Measurement type
  • Primary value
  • Units
  • Coordinates (formatted string)
  • Timestamp
GeoJSON Export: Produces standard GeoJSON with:
  • Feature collection structure
  • Geometry in geographic coordinates (WGS84)
  • Properties with measurement values and metadata
  • Coordinate transformation applied automatically
GeoJSON exports can be re-imported in future sessions to restore measurements.
PDF Export: Creates a formatted PDF document using jsPDF with:
  • Measurement summary header
  • List of all measurements with values and units
  • Timestamp information
  • Coordinate details where applicable
Geometric Calculations
The widget uses Turf.js for accurate geometric calculations:
  • Distance calculations use geodesic methods for accuracy across large areas
  • Area calculations account for coordinate system distortion
  • Circle measurements use true geodesic circles, not map projection circles
  • Coordinate transformations preserve geometric accuracy
Clear All Functionality
The Clear All button removes all measurements from the widget and map. A confirmation dialog appears before clearing to prevent accidental deletion. Dialog text is configurable by developers in the settings.
Responsive Design
The widget adapts to different panel widths:
  • Button layout adjusts based on configured column count
  • Measurement list scrolls independently when content exceeds height
  • Dropdown menus position intelligently to avoid viewport edges
  • Compact mode provides optimized layout for narrow panels
Error Handling
The widget includes error handling for:
  • Module loading failures (ArcGIS JavaScript API modules)
  • Invalid import data
  • Geometric calculation errors
  • Coordinate transformation failures
Error messages display in the widget when operations fail, allowing users to understand and correct issues.
1 Comment
Brian_McLeer
Developer Edition 1.19 was released today (11/13). I tested the widget and everything looks to functioning the same as it was at DE 1.18.
Contributors
About the Author
GIS Administrator/Developer at City of Grand Junction, CO.
