How should I write html code to allow the webmap automatically zoom to layer?
2473
10-26-2015 03:20 AM
VladimirSopivnik
Hello. I am working in a Petroleum company and I am not a professional website designer. I made a webmap in arcgis online for the company's website and paste the html code at the backstage of the website. It performs fine.
Now they have a requirement which is, they want to click a hyperlink on the website and the webmap on the same page will automatically zoom to a specific position. It should be an easy job, but I don't know how to write the html code. Can anybody help me? Thanks.
BillChappell
Occasional Contributor II
If you using ArcGIS.com have you considered bookmarks? You described what they do.
Bookmark places—ArcGIS Online Help | ArcGIS
If you were into JavaScript, you could replace the hyperlink with a button, and when it's clicked run a function, The function would change the map extents. aka bookmark.
JakeSkinner
Esri Esteemed Contributor
HI Vladimir,
Take a look at the section 'Define extent' in the below link:
Use URL parameters—ArcGIS Online Help | ArcGIS
You can define the extent of the map directly in the URL.
