The ArcGIS Online (AGO) Security Advisor has been updated. For information regarding this product, see the ArcGIS Online Security Advisor story map. You can launch the app from the ArcGIS Trust Center. See the release notes below!
This release focuses on the up coming AGO HTTPS only enforcement September 2020. The HTTP Check is no longer beta and supports processing up to 1000 content items by analyzing the item page and the item's data information (if it can be handled as JSON - the HTTP Checker's help page identifies the content data types that are not processed). Improvements will be made as needed.
Use the search by just pressing the 'enter' key to scan all available items or enter keywords into the search filter to focus on specific content items. For more information, check out the HTTP Checker's help content once you've logged into the application.
The AGO HTTPS only enforcement is expected to be implemented in September 2020.
v2.0.4 - 2019/DEC/06
HTTP Check
Application Changes
Settings Advisor
Regards,
Esri Software Security & Privacy Team
