Help with showing modern disctricts
1243
03-23-2021 07:04 PM
by Anonymous User
Not applicable
Hi, im new to using ESRI redistricting online and I need to know if the premade district map for a given state is the current map for districts in the US.
Attached is a screenshot from a new, unedited file in the online app. For context, it is showing Mississippi.
SFerguson
Hi Isaiah - What you are seeing on the map is an unassigned set of counties at the state level.  To create districts, you need to assign them using the software. This set of Census PL data is current as of 2010.  The 2020 Census PL data will be populated in the August/September timeline once the Census Bureau has released the new data.
SFerguson
