FYI: 311 Citizen Request Dashboards
4454
13
11-27-2018 09:55 PM
ViTran
They're very nice dashboard. Thanks for sharing!
I'm just curious about the dashboard from the City of Baton Rouge, LA. How can they make those tabs separately and the general filter? Is there any custom coding involved?
Thanks!
DerekLaw
Esri Esteemed Contributor
Hi Vi,
The tabs are created by stacking Dashboard elements, and the general filter is enabled with selectors. All of this can be done with configuration, no coding needed.
Hope this helps,
ViTran
Hi Derek,
Thanks for your tips. What I needed to learn is "Grouping the elements". It works perfectly!
Best,
AprilChipman
Is it possible to see a sample of the data used to create these dashboards? Is all of the data in one layer, or are they pulling from multiple layers?
DerekLaw
Hi April,
I don't own these Dashboards, nor did I create them. All were shared with me via several different methods. So unfortunately, I can't comment on your question about the data sources. Sorry.
Did you have a specific question that you wanted to ask?
Reply
AprilChipman
Thanks Derek!
I was just trying to determine if all of the data was coming from the same feature service, or if they were somehow displaying data based upon other layers.
For example, I have a layer of Storm Damage points and a layer of county boundaries. I want to show how many points are in each county on my dashboard.
Reply
by Anonymous User
Not applicable
April,
Our data is available at 311 Citizen Requests for Service | Open Data BR
We are using a few boundaries layers in order to do spatial filters.
I built a web map for every category of 311 call and added the boundary layers to each:
I hope this helps.
JeremyJung1
Hi Brandon,
Awesome integrating 311 calls and building a beautiful Dashboard. I am looking to doing something similar. Some of my clients use 311 for public works request and etc. I was just wanted to know how you are integrating 311 calls that update in your Dashboard and are you using python to automate and create points every time you get a new 311 service call or are field workers using Survey123 or collector? We are using AGOL to host Dashboards and other web maps. Thank you in advance for any help you can provide.
Jeremy
by Anonymous User
Not applicable
Hi Derek,
I work with the City of Baton Rouge and made the 311 Citizen Request for Service dashboard.
Thank you for highlighting our dashboard! It's always nice to have your work recognized.
If anyone has any questions I'd be happy to share any tips or tricks.
Thanks again,
Brandon Jumonville
