pulling data out of map click .run
4056
02-26-2015 12:25 PM
TimLohnes
New Contributor II
Hi all,
Just playing around with esri-leaflet to see if I can get everything done easier.
I a bit of a novice, but was able to quickly access my data attributes on map click with Tasks.identifyFeatures.
However I don't know how to get that data out of that task and into a variable so I can process the selection elsewhere.
In the console.log in run, I can get all the info I want. How do I pass it back to the parcels variable in map.on and then get access to the data?
map.on('click', function (e) {
  parcels = queryOnMapClick(e);
function queryOnMapClick(clicked) {
        var clickedParcels = L.esri.Tasks.identifyFeatures(pathtoservice)
            .on(map)
            .at(clicked.latlng)
            .layers('visible:4')
            .run(function (error, featureCollection, response) {
                 console.log("UTC Offset: " + featureCollection.features[0].properties.APN_PQ);
Thanks for any tips.
-Tim
OwenEarley
Occasional Contributor III
The run function is an asynchronous task - you may be attempting to use the parcels variable before the run function has assigned anything to it.
I haven't tried leaflet yet but you should look into promises.
OwenEarley
You could assign the variable in your run function:
     queryOnMapClick(e);
          .on(map)
          .at(clicked.latlng)
               parcels = featureCollection.features;
OwenEarley
Alternatively, return a value from within the run function:
            .on(map)
            .at(clicked.latlng)
                return featureCollection.features;
TimLohnes
New Contributor II
Thanks, Owen. I can't get access to the data  anywhere outside of .run.
With your examples most of the time it would just say undefined.
if I return the main variable 'clickedParcels' at the bottom like
  1.            .run(function (error, featureCollection, response) {
  2.                 console.log("UTC Offset: " + featureCollection.features[0].properties.APN_PQ);
  3.                 return featureCollection.features;
  4.             });
  5.            return clickedParcels;
  6. }
In the console I get some response from console.log(parcels):
XMLHttpRequest {statusText: "", status: 0, responseURL: "", response: "", responseType: ""…}
But I haven't been able to figure out how to retrieve the data out of that. I'm just trying to get a set of data that I can plug into other functions.
OwenEarley
TimLohnes
New Contributor II
Thanks, Owen. I believe that to be the problem. We'll see if I can make it through promises unscathed....
