place esri leaflet geocoding control outside of the map
3222
02-21-2018 09:52 AM
TylerWaring1
New Contributor III
Greetings,
I am using the esri-leaflet geocoding control in a map application but need to add it to a bootstrap modal popup for my workflow. I've tried
   var searchControl = L.esri.Geocoding.geosearch({container: "findbox"});
which would work in the esri javascript api.
How could this be done using esri-leaflet?
Thanks, Tyler
Reply
JohnGravois
Reply
JohnGravois
Reply
TylerWaring1
New Contributor III
It looks awesome. Thanks John!
Reply
PatrickMcKinney1
Occasional Contributor III
The Esri Calcite Maps project demo's have some demos of doing this as well. It places the search control in the navivgation above the desktop breakpoint, and then in the hamburger menu below the breakpoint.  It also makes the switch on the resize event.  Did you contribute to that solution JGravois-esristaff
Reply
JohnGravois
nope. that's all alaframboise-esristaff‌. and he just mucked with the original CSS.
Reply
