I am using esri's feature service and ersi-leaflet library to display my map. The following code snippet is used to display
the countries
featureURL = "http://dev.xxxxx.org/arcgis/rest/services/MEP/noRelate_tester/FeatureServer/0"
var countries = L.esri.featureLayer(featureURL,
style: getStyle,
onEachFeature: onEachFeature
}).addTo(map);
At this time, it is displaying all the countries.
I'd like to display (or highlight) only the countries that satisfies a certain filter or query.
For example, I want to display only the countries that satisfy the filter/query type = SDG.
I reviewed the docs and examples for esri-leaflet library but am totally lost as to how use the query method.
Can someone point me to an example that show how to use the filter/query to do the above
Chris
The query method has examples on Esri Leaflet.
Example 1: https://esri.github.io/esri-leaflet/examples/querying-feature-layers-1.html
Example 2: https://esri.github.io/esri-leaflet/examples/querying-feature-layers-2.html
From Esri Leaflet Issues, I found a problem similar to yours.
Since you pass a GeoJSON feature you have access to attributes, like the "filter" attribute.
function filter(feature) {
return feature.properties.type === "SDG";
var countries = L.esri.featureLayer(featureURL,{
filter: filter,
style: getStyle,
}).addTo(map);
Issue #214: https://github.com/Esri/esri-leaflet/issues/214
instead of fetching all the features from the service and filtering on the client, it's a better to only ask ArcGIS Online/Server for the features you want (using the where constructor option).
