Topology and Error Inspector in Arc Pro -- "Mass" Fixes not working
1224
09-13-2021 12:29 PM
ellen_fehrs
I have a large set of lines and I am trying to get rid of pseudo nodes.
When I use the Error Inspector in ArcMap, it correctly removes all the pseudo nodes.
When I use the Error Inspector in Arc Pro with the exact same topology rule and the exact same lines, it seems to randomly delete line segments. Literally nothing is different between the two versions.
I know a lot of people are having issues with topology editing in Pro, and I was curious if anyone knew whether ESRI had changed some aspects of the Error Inspector? Whether I create the topology itself in ArcMap or Arc Pro or even ArcCatalog does not seem to matter...all that matters is where the editing via Error Inspector takes place.
This is really frustrating, and I can't find many sources for topology editing in Pro beyond really basic tutorials where they go through fixing one error at a time.
ellen_fehrs
Another point: Arc Pro's Error Inspector is ridiculously bad at recognizing when features do and do not meet the cluster tolerance. So many errors squeak by compared to the Error Inspector in ArcMap!
