I am trying to Display polygon around sickestZIP in my following code, but it is not happening. please help me.
466
05-29-2020 08:30 AM
VishalRaiyani
gray<!DOCTYPE HTML>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>ArcGIS JavaScript Tutorials: Add layers to a map</title>
<style>
    html, body, #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
</style>
        <link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/themes/light/main.css">
        <script src="https://js.arcgis.com/4.15/"></script>
<script>
        require([
          "esri/Map",
          "esri/views/MapView",
          "esri/widgets/BasemapToggle",
          "esri/layers/FeatureLayer",
          "esri/layers/MapImageLayer",
          "esri/renderers/ClassBreaksRenderer",
          "esri/symbols/SimpleMarkerSymbol",
          "esri/layers/GraphicsLayer",
      "esri/tasks/support/Query",
      "esri/tasks/QueryTask",
      "esri/geometry/geometryEngine"
        ], function(Map,MapView,BasemapToggle,FeatureLayer,MapImageLayer,ClassBreaksRenderer,SimpleMarkerSymbol,GraphicsLayer,Query,QueryTask,geometryEngine) {
        var map = new Map({
            basemap: "gray"
        var view = new MapView({
            container: "viewDiv",
            map: map,
            center: [-100.000000,31.000000],
            zoom: 13
        var basemapToggle = new BasemapToggle({
            view: view,
            nextBasemap: "topo-vector"
        view.ui.add(basemapToggle, "bottom-right");
        var featureLayer = new FeatureLayer({
            url: "https://services6.arcgis.com/cmKWjJDTp7lPppjM/arcgis/rest/services/Zip/FeatureServer/0"
        map.add(featureLayer);
            featureLayer.when(function(){
                view.extent=featureLayer.fullExtent;
        var medianAgeLayer = new MapImageLayer({
            url: "https://demographics9.arcgis.com/arcgis/rest/services/USA_Demographics_and_Boundaries_2019/MapServer"
        var cbrenderer = new ClassBreaksRenderer({
            field: "Age"
            cbrenderer.addClassBreakInfo({
                minValue: 19,
                maxValue: 40,
                symbol: new SimpleMarkerSymbol({
                style: "diamond",
                color: "#9ACD32",
                minValue: 41,
                maxValue: 52,
                style: "diamond",
                color: [0,0,255,0.2],
            featureLayer.renderer = cbrenderer;
        var graphicsLayer = new GraphicsLayer({
            graphics: []
        map.add(graphicsLayer);
        var gCriteria01Geometry;
        var gCriteria02Geometry;
        function countPerZIPCode(inputLayer){
            var q = featureLayer.createQuery();
            q.outFields = ["ZIP"];
            return inputLayer.queryFeatures(q).then(function(response){
                var dict = {};
                var zip;
                response.features.forEach(function (item) {
                    zip = item.attributes.ZIP;
                    if (dict[zip] == undefined) {
                        dict[zip]= 1;
                    else
                        dict[zip] = dict[zip] + 1;
                return Object.keys(dict).reduce(function(key1,key2){
                    return dict[key1] > dict[key2] ? key1 : key2;
        function bufferByDistance(sickestZIP){
            var q = new Query();
            q.where = "ID = '" + sickestZIP + "'";
            q.returnGeometry = true;
            var medianAgeQueryTask = new QueryTask({
            return medianAgeQueryTask.execute(q).then(function(response){
                return response.features[0].geometry;
            }).then(function(sickestZIPGeometry){
                gCriteria01Geometry = geometryEngine.buffer(
                    sickestZIPGeometry,
                    2,
                    "miles"
                displayMyPolygon(gCriteria01Geometry, "red");
                displayMyPolygon(sickestZIPGeometry, "green");
        view.when(featureLayer.when()
                    .then(countPerZIPCode)
                    .then(bufferByDistance)
</script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
