Setting up PostgreSQL database for the portal (running scripts/license problem)
3669
02-21-2013 02:37 AM
AndersonSandes
Dear colleagues:
I am trying to install geoportal through Windows 7 using PostgreSQL.
I am trying to set up a PostgreSQL database for the portal; specifically I am trying to run the "grants" and the "create scheme" scripts that are in the PostgreSQL folder.
I have copied and pasted all of the elements of the "bin folder" to the PostgreSQL folder. Whenever I run "grants_pg [host] [port] [database] [geoportal schema] [userToconnect] [geoportalUser"], I get the expected "Enter password for new role" message, but I am unable to type anything in the cmd window.
It says I need to obtain a license at http://www.apache.org/licenses/LICENSE2.0
How can I obtain this license?
I copied the information I found on the URL above to a txt document and included the txt document inside the PostgreSQL folder. I ran the "grants_pg.cmd" again and obtained the same message as before (I need to obtain a license).
If you can tell me how I can effectively run this first script, I would be very grateful!!
Thanks.
LaurelKish
Try this link :
The download button is at the top right side of the page.
TinusFerreira
Hi
Just type the password and press enter, it wont look like you are entering anything but you are.
