I'm installing and testing the Geoportal Server 1.2 for the first time. There is something amiss with the LDAP configuration. Our metadirectory is "eDirectory" and I'm not sure if the setting for the initialContextFactoryName="com.sun.jndi.ldap.LdapCtxFactory" in the gpt.xml file is correct. Does this parameter need to change if you are running eDirectory?
The error is the gpt log file is
com.esri.gpt.framework.security.identity.IdentityException: Unable to connect to LDAP.
at com.esri.gpt.framework.security.identity.ldap.LdapIdentityAdapter.newServiceConnection(Unknown Source)
at com.esri.gpt.framework.security.identity.ldap.LdapIdentityAdapter.authenticate(Unknown Source)
at com.esri.gpt.control.identity.LoginController.processSubAction(Unknown Source)
at com.esri.gpt.framework.jsf.BaseActionListener.processAction(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.apache.el.parser.AstValue.invoke(AstValue.java:191)
at org.apache.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:276)
