I am using the "Extract Data and Email Task" model with associated scripts in my Geoportal 1.2.2 exactly 'as-is' from the System Toolbox. Only changes made were those required by documentation, ie. SMTP email server, To/From email addresses, subject line, after adding it to my .mxd. When I use the data download tool within Geoportal, I receive a copy of the schema, but no records for my downloaded data. This occurs when choosing both a shapefile or file geodatabase as my export format. Has anyone else had this problem and what is the solution? Thanks.
