Erfaringer med ARCADE
196
8
02-25-2020 01:33 AM
SanneMikkelsen
Mon der er nogen der har erfaringer med ARCADE og har lavet labels, der viser z-værdien på punkter? Jeg har fundet svar på Geonet, som ikke virker for mig:-(
Tags (1)
Reply
XanderBakker
Esri Esteemed Contributor
Hi Sanne Mikkelsen ,
Sorry for answering you in English, but I don't speak Danish. From what I understand from the translation you want to label the Z value of a point. I asume you have tried:
Geometry($feature).z
This should work. I just tried and created a point geometry with a Z value using the playground and accessed the z property and it worked like normal:
var pointJSON = {"x": 1000000, "y": 1000000, "z": 15.123, "spatialReference": { "wkid": 3857 } };
var pnt = Geometry(pointJSON);
return pnt.z;
Do you get any error message or is the result just null?
Reply
XanderBakker
return pnt.z;
Reply
SanneMikkelsen
Hi Xander
Yes I have already tried
I just get Null 😞
Reply
XanderBakker
Hi SanneMik ,
Have you verified that the information was published with Z-values? Null value would be returned if you don't have z-values (z not enabled) or they are filled with null values.
Reply
SanneMikkelsen
Jubii! It works now.
I found out that it is the "test"-function that does not work properly. And the OK-button is not translated right to danish. UPS.
Thank you for your quick answer.
I adjusted it to
'Kote ' + Round(Geometry($feature).z, 2)
Nice:-)
XanderBakker
Hi SanneMik ,
Congratulations. I am glad you could make it work!
KlausDons3
Hej Sanne
Jeg melder fejlen i oversættelsen på den danske version. Det er på høje tid at vi får det fikset.
KlausDons3
Hi Sanne
Vi fik oprettet en BUG på oversættelsesfejlen så vi forhåbentligt kan få det rettet til én af de kommende versioner af ArcGIS Online:
BUG-000129191: In the Danish edition of ArcGIS Online there is a translation error in the Arcade editor window, the OK button is translated to '".prvs" er en ugyldig fil til en enkeltbrugerautorisation.' instead of OK.
Tak fordi du gjorde os opmærksom på problemet.
Bedste hilsner
Klaus
SanneMikkelsen
Hej Klaus
Fint at det bliver rettet på et tidspunkt. Det var dog ikke helt den samme tekst der var på min, men mon ikke det bliver rettet alligevel.
Ellers skal jeg gerne sende et screendump.
/Sanne
Reply
