COS Hydrants
858
05-12-2017 08:16 AM
TiffanyRufo
Occasional Contributor II
5 2 858
As part of the ECGISAB I will be trying to post periodically about the projects that I have underway here at The City of Sandusky.
Today I would like to put forward the second largest GIS system that we have currently up and running within the city. The hydrant inventory began as a Fire Department project during my stint as a part-time employee here at the city. 3 guys from Fire agreed to take their phones and a collector app out and pick up as many hydrants as they could. In three days they collected everything you see below:Hydrant and knox box locations
   The above image is where the hydrant inventory stayed until about a week ago. Water Department came to me and said that they were going to start hydrant flushing soon and would like to utilize the GIS capabilities we had talked about months ago. Today we have a beta system in place that is being used in the field as I type this. The workflow looks something like this:
  • Water Department field dude takes a Juniper Geode unit and tablet into the field with him as he does hydrant flushing.
  • He begins flushing
  • While the hydrant is actively flushing he checks the collector map to see whether the hydrant has been tagged (tags it with the Geode if it has not) verifies the specs (hydrant number, model, make, ect.) for that hydrant and makes necessary changes.
  • He then checks the map to verify whether the associated water valve has been located and tagged. If not he tags it and fills out the information about that valve.
  • Finally either during the flushing or after the hydrant is closed he follows the link in the hydrants pop-up to the Survey123 app and fills out the flushing form.
All of this takes under five minutes. The Geode unit connects to the tablet via blue tooth, and is rugged enough to take a beating in the field if surviving a fall off of a truck bumper into the roadway is any indication (my guys are pros at field testing tech, very thorough). The tablet handles all of the apps; Collector, Survey123 and GeodeConnect.
So far it is working remarkably well, and the guys in the field aren't too inconvenienced by it. The first run will be the hardest, there is lots of data to collect, but the consensus is strong that once it is finished it will be well worth it.
I'll dive a little deeper into the inner working from here out. Mostly pictures below:
What the map looks like in the feild. Blue are valves, red are hydrants.
Collector map view
Hydrant pop up with linked Survey123 form
The Survey123 Form is linked directly from the hydrant pop-up. There is a nifty bit of formatting you can do that will auto populate fields within the form to reduce data entry and error. For this form the hydrant ID number auto populates to tie the records.
Quick view of the Surevy123 form for flushing
I will eventually need to restructure the hydrant point file schema to better reflect the workflow for the guys. There has also been a request for a maintenance ticket related table. Just goes to show that a health application/system is always evolving to fit the needs of the user.
I am happy to answer and questions about the structure or share resources with anyone who might want them .
Thanks for reading!
2 Comments
IsmaelChivite
Esri Frequent Contributor
Really nice work!  Thanks for sharing.
https://community.esri.com/groups/survey123?sr=search&searchId=8e5d72db-28d6-49ff-a525-1a9c32476c53&...‌  https://community.esri.com/groups/mobile-gis?sr=search&searchId=36939f2d-7ab8-45aa-b2f5-2ad7e50ab6e4...‌  https://community.esri.com/community/gis/applications/collector-for-arcgis?sr=search&searchId=eba95a...
Quick question: Does the content from the Hydrant Flushing Form get stored as a new related record?
This is a very interesting combination of Collector and Survey123. I  wonder  if you are  also considering using Workforce for ArcGIS and Navigator.
TiffanyRufo
Thank you Ismael! I couldn't have put this together without all of the wonderful documentation and blog posts available on Survey123.
Right now it does not store the data as a related table but that is something that I would love to work on if there is a way to do so. At the moment it is a Survey123 Flushing Form that the field guys just follow a link to. I was able to use one of your posts about Survey123 to auto populate the Hydrant ID number into the form so that we can relate the records back should we need to look at them.
The way Survey123 breaks down the data is extremely helpful to our Water Department guys. It allows them to see what problem areas exist and informs their workflows for hydrant repairs.
The goal is to ultimately tie in both workforce and navigator to this system, but the GIS program here at The City of Sandusky just started back in August 2016. We are taking baby steps and focusing on collecting correct data before integrating more app solutions (The guys are very open to new technology but I would hate to sour them on too much!)
About the Author
GIS Analyst for the City of Sandusky. Also worked as an Intern at Erie Soil and Water Conservation District. BGSU graduate: December of 2016 - BS in Biology with a double minor in General Science and Studio Art.
