ArcGIS 10.2 - Referenced Raster Mosaic hillshade function?
4438
6
02-09-2016 04:10 AM
VincentLaunstorfer
I just discovered the referenced Raster Mosaic using function such as hillshading. It looks great!
However, how could I adjust the display (file attached) in order to show only shades (black) and not the greyish parts?
I would like to use a sort of white or brown background and accentuate the relief with shades...
DanPatterson_Retired
Vince... is the attached too much?  It was just hillshade with shadows modelled
VincentLaunstorfer
Thanks. Yes it is too much. I am looking for subtle shading such as the IGN map attached... A hillshading just to accentuate the relief and overlay other layers... If this makes sense.
Currently, I experimented the Hillshading function in a Referenced Raster Mosaic with a z-factor = 0.00001
Perhaps, this is the wrong function to use?
I get your idea... I did get distracted some time ago with bump mapping Introducing the ArcGIS bump map tools | ArcGIS Blog
can't get distracted for a while... post if you find something interesting.
VincentLaunstorfer
Thanks for the Mapping Centre link on bump maps... Interesting and this need some experiments, time permitting.
The effect I am looking for is a sort of subtle shading such as the NG map sample attached. Perhaps tweaking the luminosity of the hillshading layer produced in the Referenced Modaic Dataset could help to produce a similar style...
Yes, it may but I haven't had the time to check
ArthurCrawford
Hello Vincent,
Since the hillshade function goes from 0 to 255, you could use a remap function to get rid of a range of the "grey" areas.   0 is darkest, so I would suggest starting with a 40 to 255 as nodata.     Another option would be to just apply it as symbology as we do in the World Topo Map and using the histogram.
Arthur Crawford
