Generate Item Reports in ArcGIS Online - free up storage space!
276
05-22-2024 12:35 PM
BrianBaldwin
UPDATE 5/24/24: A new 'credit/storage monitoring' solution is coming to ArcGIS Online with the June 2024 release - this page/video will be updated at that time to reflect the new workflow.
Running out of storage space in your ArcGIS Online organization? I can almost guarantee that 80% of that content... could be deleted.
There are probably dozens of feature services that are 20 GB in size, with 0 views, that were published 4 years ago.
While this might be an exagerration... it's probably closer to the truth than you think. With students uploading random datatsets or researchers working with "SUB_SAHARA_HOUSES_FINAL5", there is definitely a lot of wasted space.
The following video gives you a quick walk-through how you can generate an ArcGIS Online item report - and then use that information to narrow in on some of the top offending items.
Also - please do not delete items unless you are 100% sure that they can be removed. There may be StoryMaps or other applications that depend on some of those 'troublesome' feature services.
Thanks and let us know if you have any questions.
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
